How to set up an Amazon Timestream data source?
The following sections will detail all the information needed for setting up an Amazon Timestream data source in TrendMiner.
To add an Amazon Timestream data source, in ConfigHub go to Data in the left side menu, then Data sources, choose + Add data source.
Type name of data source, select “Amazon Timestream” from the Provider dropdown. Selecting the capabilities for the data source with the given checkboxes will open additional properties to enter, grouped in following sections:
Connection details – lists properties related to the configuration of the connection that will be established with Amazon Timestream.
Time series configuration – lists properties relevant for the timeseries data.
"Region" – enter the availability zone region within AWS cloud in which the Amazon Timestream instance is configured. For more information, please consult the AWS Documentation.
"AWS access key" – enter the access key to authenticate. This is the access key id as created in AWS IAM. For more information, please consult the AWS Documentation.
"AWS Secret" – enter the secret to authenticate. This is the AWS secret as created in AWS IAM. For more information, please consult the AWS Documentation.
“Database” – enter the name of database in Amazon Timestream. This is primarily used to test the connection liveness from TrendMiner to Amazon Timestream.
“Index query” - a query used by TrendMiner to ingest timeseries data for a specific tag. The query is expected to return a ts (timestamp) and a value. The following variables are available to be used in the WHERE clause of this query. The variables will be substituted at query execution with values.
customTypeA;ANALOG
customTypeB;DIGITAL
customTypeC;DISCRETE
customTypeD;STRING
Example queries
The following exemplary queries are based on the sample data setup in Amazon Timestream – containing a sample database with IoT sample data. Amazon Timestream will then create a sample database that contains IoT sensor data from one or more truck fleets to streamline fleet management and to identify cost optimization opportunities such as reduction in fuel consumption. For more information, please consult https://docs.aws.amazon.com/index.html.
Tag list query
This query treats the location measurements as tags of type STRING.
SELECT distinct CONCAT(truck_id, '--',measure_name) as id, CONCAT(truck_id, '--',measure_name) as name, CASE measure_name WHEN 'load' THEN 'DISCRETE' WHEN 'location' THEN 'STRING' ELSE 'ANALOG' END AS type, CONCAT(make, ' ', model, ' (', fleet , ')') AS description, CASE measure_name WHEN 'load' THEN 'kg' WHEN 'speed' THEN 'km/h' WHEN 'fuel-reading' THEN '%' ELSE '' END AS unit FROM sampleDB2.IoT
Alternative query treats the location measurements as tags of type DIGITAL. This is a somewhat less realistic case, but it serves the purpose of also demonstrating tags of type DIGITAL. Location measurements are given a random number between 1 and 10 in the matching alternative index query.
SELECT distinct CONCAT(truck_id, '--',measure_name) as id, CONCAT(truck_id, '--',measure_name) as name, CASE measure_name WHEN 'load' THEN 'DISCRETE' WHEN 'location' THEN 'DIGITAL' ELSE 'ANALOG' END AS type, CONCAT(make, ' ', model, ' (', fleet , ')') AS description, CASE measure_name WHEN 'load' THEN 'kg' WHEN 'speed' THEN 'km/h' WHEN 'fuel-reading' THEN '%' ELSE '' END AS unit FROM sampleDB2.IoT
Index query
select time as ts, CASE WHEN measure_value::double is not null THEN cast(measure_value::double as varchar) ELSE measure_value::varchar END AS value from "sampleDB2"."IoT" where concat(truck_id, '--',measure_name) = '{ID}' and time >= '{STARTDATE}' and time <= '{ENDDATE}' order by time asc
Alternative index query for digital location tags. Where we for the purpose of this demo case assign a random number to a location value for a timestamp.
select time as ts, CASE SPLIT('{ID}', '--')[2] WHEN 'location' THEN RANDOM(10) ELSE "measure_value::double" END AS value from "sampleDB2"."IoT" where concat(truck_id, '--',measure_name) = '{ID}' and time >= '{STARTDATE}' and time <= '{ENDDATE}' order by time asc
This query is applicable when the alternative tag list and alternative index query is used.
SELECT 'STATE0' as stringValue, 0 as intValue UNION SELECT 'STATE1', 1 UNION SELECT 'STATE2', 2 UNION SELECT 'STATE3', 3 UNION SELECT 'STATE4', 4 UNION SELECT 'STATE5', 5 UNION SELECT 'STATE6', 6 UNION SELECT 'STATE7', 7 UNION SELECT 'STATE8', 8 UNION SELECT 'STATE9', 9 UNION SELECT 'STATE10', 10 ORDER BY 1
