Prerequisites
  • My current installed TrendMiner version is 2023.R1.0 or higher.
    In case you are running on version 2022.R2.0 or older, please upgrade first to version 2023.R1.0.
  • I have VM console access.
    Resource
    Minimum
    Recommended
    vCPU
    8
    16
    16
    RAM
    32GB
    64GB
    64GB
    Disk space
    SSD, 200GB, 250MB/s
    SSD, 500GB, 250MB/s
    SSD, 500GB, 250MB/s
