Step 5: Validate
  • Management Interface Validation: Go to ‘Services’ page under DASHBOARD and confirm all services show a green status.
  • Data Source Connections: Go to the ‘Data Source’ page in ConfigHub and run a test Connection from the Options dropdown for each entry.
  • Access Control List (ACL) Validation: Follow the procedure detailed here and make sure you can log in and have access to all the configured data sources.
  • Monitor Verification: Send yourself a test email from the ConfigHub page to make sure the mail relay is correctly configured.
  • Speed/Indexing Check: Add any tag and ensure the indexing status reaches Up-to-date within a reasonable time. It should not take more than 1-2 minutes for TrendMiner to fully index around 5 years of data. This will depend on the tag resolution. If it does take significantly longer to index the tag or you get some error messages, involve TrendMiner technical support so we can troubleshoot.
    2023.R3.0 - tag details
    Tip
  • Tag Type Verification: Add a tag of each type available in your data source (e.g. Analog, Discrete, etc.) to ensure the tags are properly mapped and displayed in TrendMiner
ACL Validation
  1. Log in to TrendMiner at http://<trendminer_address>/
    login screen
  2. Go through the first login procedure:
    • Accept the EULA
      Tip
    • Accept the privacy policy
    • Update your password according to the password policy rules
    • Update you account information
  3. Click on 'search tags and attributes' followed by the filter icon to verify that the connections and permissions as configured in the previous sections are correct. Under 'Data sources' you should see a list of all data sources which are configured in ConfigHub and for which ACLs are assigned to the logged in user.
  4. Start typing a tag name inside of the search box.
  5. Tags that match the input will show up in the dropdown. Click on the plus icon (+) to visualize. TrendMiner displays a trend view of the tag and starts the indexing process.
