SSL
  • Private key
  • CSR for that private key
  • Certificate chain
TrendMiner only supports PEM certificates. OpenSSL can be used to convert certificates in a different format to PEM.
Once these prerequisites are fulfilled, HTTPS can be enabled via the "Action" menu on the top right.
When uploading new trusted certificates via Security - Certificates and HTTPS is enabled, SSL can be reloaded by selecting “Reload SSL” in the Actions menu of the screen.
For a more detailed guide of what is, why and how to use SSL in TrendMiner, please consult our support documents.
Certificate signing request (CSR)
Via ConfigHub a CSR can be generated.
To start, clicking the Actions menu and select “Certificate signing request”. A side panel will open to download or generate the CSR.
At the top of the side panel, you can download the CSR when it is generated on the server.
Below this section, information to generate the CSR can be provided. There are 2 options to generate a CSR, using
  • Alternative names
    With this option, it is allowed to provide alternative fully qualified domain names to be protected using the certificate. These are optional. However, the server name of the installation must be listed as well as an alternative name.
  • Wildcard
    This options allow for HTTPS on all subdomains of the provided wildcard domain. This domain is required.
When no private key is available yet, one will be generated. Uploading a new private key, might break current HTTPS/SSL and pending Certificate signing requests (CSR).
ConfigHub certificates
