How to extract context items?
TrendMiner offers two API endpoints for extracting context items. Which one to use depends on what you are trying to do.
Choose the right endpoint
"Which context items overlap with a specific time window?"
Use the Context Search endpoint: POST /context/v3/item/search. This is the same query the TrendMiner UI uses. You provide an event time interval and optional filters (keyword, component, context type, fields, labels, etc.) and get back context items whose time range overlaps with it. Use this when you are building a report, a dashboard, or any query tied to a specific process time window.
"What changed since my last sync?"
Use the Integration API endpoint: POST /integration/item/search (and its companion POST /integration/item/search/count). These endpoints filter by created or last-modified date and are optimized for incrementally syncing context items to an external system such as a data lake or BI tool. They do not require an event time interval.
Each endpoint uses a different database index optimized for its access pattern. Using the wrong endpoint will hit an unoptimized path and degrade performance at scale.
Warning
The older /context/v2/item/search endpoint is deprecated. New integrations should use either the Context Search v3 or the Integration API.
The rest of this guide covers the Integration API for sync use cases.
Authentication
All requests go to your TrendMiner instance's API. Authenticate with a Bearer token in the header:
Authorization: Bearer <your-token> Content-Type: application/json
No specific role is required. However, a service or admin user sees all context items. Regular users only see items they have permission to access -- items outside their permissions are silently excluded from both results and counts.
Use a service or admin user for sync integrations. A regular user token will silently miss items, and your external system will have an incomplete copy.
Endpoints
Endpoint | Method | Purpose |
/integration/item/search | POST | Retrieve a page of context items |
/integration/item/search/count | POST | Count the context items matching your filters |
Building a request
A minimal request body looks like this:
"filters": [
"type": "LAST_MODIFIED_DATE_INTERVAL_FILTER",
"startDate": "2026-06-01T00:00:00Z",
"endDate": "2026-06-02T00:00:00Z"
"sortProperties": ["lastModifiedDate"],
"sortDirection": "asc",
"fetchSize": 60,
"continuationToken": null
Fields
Field | Required | Description |
filters | Yes | Must contain exactly one date filter (see below). You can add other context-item filters alongside it (type, component, keyword, field filters, etc.). |
sortProperties | No | Sort by |
sortDirection | No | asc or |
fetchSize | No | Number of items per page. Defaults to 60. Only used by the search endpoint. |
continuationToken | No | Token from a previous response to fetch the next page. Only used by the search endpoint. |
Date filters
Every request must include exactly one date filter. All timestamps use ISO-8601 format (e.g. 2026-06-01T00:00:00Z).
Interval filters -- match items within a date range (both boundaries inclusive):
Filter type | Fields | What it matches |
CREATED_DATE_INTERVAL_FILTER | startDate, | Items created between the two dates |
LAST_MODIFIED_DATE_INTERVAL_FILTER | startDate, | Items last modified between the two dates |
Operator filters -- match items using a comparison operator:
CREATED_DATE_FILTER | createdDate, | Items whose created date matches the operator condition |
LAST_MODIFIED_DATE_OPERATOR_FILTER | lastModifiedDate, | Items whose last-modified date matches the operator condition |
Available operators: EQUAL, NOT_EQUAL, LESS_THAN, LESS_THAN_OR_EQUAL, GREATER_THAN, GREATER_THAN_OR_EQUAL.
Reading the response
Search response (200)
"content": [ ... ],
"page": {
"continuationToken": "abc123..."
The content array contains the context items for this page. To fetch the next page, send the same request body with continuationToken set to the value from the response. Keep filters, sortProperties, and sortDirection identical across pages.
Note: the last page of results also returns a continuation token. Use the count endpoint first to know how many items to expect, so you can verify when all results have been returned.
Count response (200)
"totalCount": 123
Handling errors
Status | Cause | Action |
400 | Validation failed (see details below) | Fix the request. Do not retry the same request. |
401 / 403 | Token is missing, expired, or lacks permissions | Refresh the token or check the user's permissions. |
429 | Too many concurrent requests | Wait the number of seconds indicated in the |
The 429 rate limit allows 5 concurrent calls to these endpoints by default. A request that cannot get a slot within 5 seconds is rejected.
Validation error details
A 400 response includes a body with error codes:
"errorCode": "VALIDATION_FAILED",
"details": {
"0": [
"key": "filters",
"message": { "code": "EXACTLY_ONE_METADATE_FILTER_REQUIRED" }
Common codes:
Code | Meaning |
EXACTLY_ONE_METADATE_FILTER_REQUIRED | You supplied zero or more than one date filter. Use exactly one. |
START_DATE_NOT_FIRST | In an interval filter, |
Setting up an incremental sync
The recommended pattern for keeping an external system up to date:
First run: call
/search/countto know how many items exist, then page through all items using/searchwith aLAST_MODIFIED_DATE_INTERVAL_FILTERor aGREATER_THAN_OR_EQUALoperator filter starting from a date far enough in the past. Sort bylastModifiedDateascending.Subsequent runs: store the
lastModifiedDateof the most recent item you processed as a checkpoint. On the next run, use aLAST_MODIFIED_DATE_OPERATOR_FILTERwithGREATER_THAN_OR_EQUALand your checkpoint timestamp. Sort ascending and page through with the continuation token.Handle rate limiting gracefully. Keep your concurrency to 1-2 parallel calls. Treat 429 responses as normal back-pressure: wait for the
Retry-Afterduration and retry.
