Enable Proxy support
When using TrendMiner, some parts of the application require internet access, such as automated upgrades, licensing, and metric collection.
Proxy configuration is only supported on single node deployments, not on virtual appliance deployments. If you're in doubt about your deployment, see this documentation to check if TrendMiner is deployed as a virtual appliance: How to check if TrendMiner is deployed as a virtual appliance?
Requirements
a configured proxy server where the TrendMiner installation has access to.
root access (or using sudo) on the TrendMiner server, either over console or over SSH
Basic Linux Knowledge (used command: vi/nano/ssh/ls/cd)
Proxy server configured with internet access (HTTPS) towards the following urls
license.trendminer.cloud download.license.trendminer.cloud
Setup in TrendMiner server
Step 1: Setup EdgeManager to be able to communicate using a proxy
create a proxy config file
vi /etc/systemd/system/tm-edge-manager.service.d/proxy.conf
add the following content
[Service] Environment="http_proxy=login:password@proxyservernameorip:port" Environment="https_proxy=login:password@proxyservernameorip:port" Environment="no_proxy=localhost,127.0.0.1,.cluster.local,10.42.0.0/24,10.42.1.0/24,10.41.1.0/24,10.41.0.0/24" Environment="HTTP_PROXY=login:password@proxyservernameorip:port" Environment="HTTPS_PROXY=login:password@proxyservernameorip:port" Environment="NO_PROXY=localhost,127.0.0.1,.cluster.local,10.42.0.0/24,10.42.1.0/24,10.41.1.0/24,10.41.0.0/24"
Make sure to replace “login:password@proxyservernameorip:port” with the proxy server for your organization.
Make sure to have your server IP listed in the NO_PROXY and no_proxy variables above also, or add the ip range.
Environment="NO_PROXY=localhost,IPOFSERVER, ...." Environment="no_proxy=localhost,IPOFSERVER,....."
or
Environment="NO_PROXY=localhost,IPOFSERVER/24, ...." Environment="no_proxy=localhost,IPOFSERVER/24,....."
reload systemctl deamon and restart EdgeManager to activate the changes
# systemctl daemon-reload # systemctl restart tm-edge-manager.service
Step 2: setup kubernetes specific proxies
Login to the the TrendMiner Instance over SSH/Console
Create a file /etc/ansible/facts.d/proxy.factusing vi and add the following content
{ "http_proxy": "http://<PROXY_IP>:3128/", "https_proxy": "http://<PROXY_IP>:3128/", "no_proxy": "SERVERIP,localhost,127.0.0.1,.cluster.local,10.42.0.0/24,10.42.1.0/24,10.41.0.0/24" }Replace or change the following part in this file:
<PROXY_IP>:3128 with the ip and port and authentication of the proxy server to use
replace SERVERIP with the ip or subnet of your server e.g. 10.0.1.5 or 10.0.1.0/24
Save the file
Run configure-tm-platform (this will bring down TrendMiner, and restart it)
# ansible-playbook /mnt/data/ansible-playbooks/platform/configure-tm-platform.yml
Restart tm-config-operator / tm-metrics-forwarder as following
# kubectl rollout restart -n tm-config-operator-system deployment.apps/tm-config-operator-controller-manager deployment.apps/tm-config-operator-controller-manager restarted # kubectl rollout restart -n tm-metrics-forwarder-system deployment.apps/tm-metrics-forwarder deployment.apps/tm-metrics-forwarder restarted
