Monitoring / Alert tiles
An alert tile enables you to check visually the state of your TrendHub monitors based on the criteria you set. When a monitor alert is triggered, the resumption of a "Normal status" will see the trigger reset.
You can create an alert tile in DashHub that provides a visual trigger when prescribed limits are exceeded.
For example, if a water tank level is low, you can create a tile that is connected to a monitor specifically set up to read water levels. When the limit has been exceeded, the trigger is released, and the visual alert is updated.
When a monitor is not enabled in the monitoring tab in the top bar (accessible in any hub), the associated monitor tile will indicate the loss of connection.
Your tile has a clickthrough to the monitor functionality, but only when the monitor is triggered. The clickthrough leads you to TrendHub at the timeframe where the monitor was triggered.
Only monitors based on a value based search and operating area search can be selected as an alert tile. Monitors based on fingerprints, similarity search and digital step search are not yet available.
- Start a new or open a saved dashboard and click the “Action” button on the dashboard bar.
- The “Create new tile” panel is shown on the righthand side of the screen.
- Provide a tile name and select a monitor by clicking the dropdown field.
- Provide visual definitions with icons and colors for the normal state (no search result) and the trigger state (search result).
- To add the tile to the dashboard, click the “Add new tile” button at the bottom of the side panel.
