Dashboard export
You can export the content contained on your dashboard in HTML format.
Once your dashboard has been built, you will be able to run it immediately. Over time you may want to report the details contained on and behind your dashboard. Using the dashboard export option you can create HTML reports of your process events very easily. This can be helpful when, for example, creating a shift handover report.
To export your dashboard in report form:
- In DashHub, select your dashboard of interest.
- Click on the "Actions" button.
- In the drop down menu, select "Export as HTML".
Context Items in the views that make up your dashboard are now exported in full on the HTML page in report format. When you examine the exported report you will see base information associated to each tile neatly listed.
Notice
The Dashboard export will only export the context item information. Other information on your dashboard, like trends, monitors, text tiles, will not be included.
