Prerequisites
My current installed TrendMiner version is 2023.R4.0 or higher.
In case you are running on version 2023.R3.0 or older, please upgrade first to version 2023.R4.0.
I have VM console access.
I have a recent VM snapshot.
I have a recent database backup.
Danger
The upgrade from 2023.R4.0 to 2024.R1.0 contains an important database migration. We therefor explicitly want to emphasize again the importance of taking a database backup before triggering the upgrade.
Single node installs only. I have updated the CentOS 7 default repository references.
sed -i 's/^mirrorlist/#mirrorlist/g' /etc/yum.repos.d/CentOS-*.repo sed -i 's|#baseurl=http://mirror.centos.org|baseurl=http://vault.centos.org|g' /etc/yum.repos.d/CentOS-*.repo
The upgrade from 2023.R4.0 to 2024.R1.0 contains an important database migration. This migration will need additional free disk space compared to regular upgrades. If there is not enough free disk space the upgrade will not start!
Required free disk space for this upgrade: 25GB + 30 x the size of a compressed database backup.
How to check:
Create a new backup in ConfigHub or Edge Manager.
When finished, download the newly created backup.
Check the size of the backup (the tar.gz file).
Example: downloaded backup = 5GB => required free disk space = 25GB + 30 x 5GB = 175GB.
The available disk space can be checked in Edge Manager -> Diagnostics. In case there is insufficient free disk space the disk needs to be extended before upgrading TrendMiner. Note that once the disk is extended the extended disk space cannot be reclaimed anymore (it is not possible to shrink the disk space after the upgrade).
My system meets the minimum system requirements as listed below.
Resource
Minimum
Recommended
vCPU
8
16
16
RAM
32GB
64GB
64GB
Disk space
SSD, 200GB, 250MB/s
SSD, 500GB, 250MB/s
SSD, 500GB, 250MB/s
I have read and understood the changes related to the ConfigHub access after the upgrade as documented here: How to restore your ConfigHub access after the 2024.R1.0 upgrade?
