Step 5: Validate
Management Interface Validation: Go to ‘Services’ page under DASHBOARD and confirm all services show a green status.
Data Source Connections: Go to the ‘Data Source’ in page and run a test Connection from the Options dropdown for each entry.
Access Control List (ACL) Validation: Follow the procedure detailed here and make sure you can log in and have access to all the configured data sources.
Monitor Verification: Send yourself a test email from the ConfigHub page to make sure the mail relay is correctly configured. Follow instructions here.
Speed/Indexing Check: Add any tag and ensure the indexing status reaches Up-to-date within a reasonable time. It should not take more than 1-2 minutes for TrendMiner to fully index around 5 years of data. This will depend on the tag resolution. If it does take significantly longer to index the tag or you get some error messages, involve TrendMiner technical support so we can troubleshoot.
Tip
Tag Type Verification: Add a tag of each type available in your data source (e.g. Analog, Discrete, etc.) to ensure the tags are properly mapped and displayed in TrendMiner
