Server requirements
Server requirements for both the TrendMiner Server and the Plant Integrations connector are discussed in the following sections.
TrendMiner Server
The table below summarizes the system requirements for the (virtualized) TrendMiner server. TrendMiner always recommends provisioning the Recommended specifications to ensure a consistent and performant UX.
As of TrendMiner version 2024.R2.0 the minimal hardware requirements will be increased. In case you are installing a new TrendMiner appliance you might want to comply already with the new requirements. Expected changes are:
Minimum disk space: 200GB -> 500GB
Minimum RAM without MLHub: 32GB -> 64GB
Minimum RAM with MLHub: 64GB -> 64GB + 1GB per active kernel (per user) + 256MB per notebook tile (per user per dashboard)
Minimum vCPU without MLHub: 8 -> 16
Minimum vCPU with MLHub: 16 -> 16 + 1 core per 4 active kernels (per user) + 1 core per 8 notebook tiles (per user per dashboard)
A few important notes on the disk space requirement:
The required disk space highly depends on the usage of the system: number of users and the amount of items they save on the system + the number of tags which are added and indexed. If usage increases further disk space increases might be required.
TrendMiner strongly advises thick provision of the VM TrendMiner is running on to avoid over-provisioning and increase write performance. Over-provisioning can result in TrendMiner going down because of a full disk without upfront alarm to the TrendMiner admin.
VMware ESXi 5.5 or higher.
Microsoft Windows Hyper-V Server 2012 R2 or higher
Other prerequisites:
The TrendMiner appliance uses Kubernetes (K3S) as its infrastructure layer, which needs a range of IP addresses for internal communication between different pods and services. The following IP addresses should not be used by other applications/servers running on the network on which TrendMiner is deployed:
Resource | Amount |
vCPU | 2 |
RAM | 2GB |
Disk Space | 5GB |
Windows Server 2012 R2 or higher
IIS 7 or higher
.NET Framework 4.8 or higher
IIS Web Deploy 3.5 or higher
For Aveva PI: the PI AF SDK drivers provide good connection pooling and efficient transfer. The Plant Integrations and historian need not be co-located.
For other historians, TrendMiner recommends installing Plant Integrations on the historian server, as their drivers are normally firewall-unfriendly or latency-sensitive, mostly using DCOM. Experience tells us that an installation on the historian server leads to a better performance than installations that simply use the same network.
