Known Limitations
  • Conditional formatting for the Gantt will not consider any changes to durations propagated through the use of live mode. To see the updated coloring users would have to refresh the chart.
  • Embedding TrendMiner in external applications is limited to Microsoft Teams. Extensions to improve this functionality and make it more robust will come later.
  • External content tiles in dashboard need cookies to properly load all content (and be able to login when required).
  • The action displayed on the right-side panel of ConfigHub when a service is restarted, is no longer visible.
