Prerequisites
Warning
As of this release the implementation of the /provider endpoint for custom connector implementations is required. In case you connect to a data source via a custom connector, please make sure this endpoint is available before upgrading your installation. Contact support if you are in doubt about the implications.How to write your own time series data connector: step-by-step quick start guide
  • My current installed TrendMiner version is 2023.R3.0 or higher.
    In case you are running on version 2023.R2.0 or older, please upgrade first to version 2023.R3.0.
  • I have VM console access.
    Resource
    Minimum
    Recommended
    vCPU
    8
    16
    16
    RAM
    32GB
    64GB
    64GB
    Disk space
    SSD, 200GB, 250MB/s
    SSD, 500GB, 250MB/s
    SSD, 500GB, 250MB/s
