Server requirements
Server requirements for both the TrendMiner Server and the Plant Integrations connector are discussed in the following sections.
TrendMiner Server
The table below summarizes the system requirements for the (virtualized) TrendMiner server. TrendMiner always recommends provisioning the Recommended specifications to ensure a consistent and performant UX.
Table 1. TrendMiner Server - Hardware requirements
Resource
Minimum
Minimum with MLHub[a]
Recommended
vCPU
8
16
16
RAM
32GB
64GB
64GB
Disk
SSD, 200GB, 250MB/s
SSD, 500GB, 250MB/s
SSD, 500GB, 250MB/s
[a] Contact your Customer Success Manager for more information on MLHub Notebook and Machine Learning Model capabilities
  • VMware ESXi 5.5 or higher.
  • Microsoft Windows Hyper-V Server 2012 R2 or higher
Other prerequisites:
  • Gigabit Ethernet or better is required for TrendMiner to work.
  • The TrendMiner appliance uses Kubernetes (K3S) as its infrastructure layer, which needs a range of IP addresses for internal communication between different pods and services. The following IP addresses should not be used by other applications/servers running on the network on which TrendMiner is deployed:
Table 2. Plant Integration requirements
Resource
Amount
vCPU
2
RAM
2GB
Disk Space
5GB
  • Windows Server 2012 R2 or higher
  • IIS 7 or higher
  • .NET Framework 4.8 or higher
  • IIS Web Deploy 3.5 or higher
  • For Aveva PI: the PI AF SDK drivers provide good connection pooling and efficient transfer. The Plant Integrations and historian need not be co-located.
  • For other historians, TrendMiner recommends installing Plant Integrations on the historian server, as their drivers are normally firewall-unfriendly or latency-sensitive, mostly using DCOM. Experience tells us that an installation on the historian server leads to a better performance than installations that simply use the same network.
