Application Enhancements
  • Improved editor for formula creation in TrendHub.
  • Improved visualization options when dealing with very big and small numbers throughout the TrendMiner application. Users can also adjust the displayed accuracy per tag.
  • Support of Duration and Type fields in ContextHub Multi scatter plots.
  • Quality of life improvements for notebooks.
  • Value Based Search on digital & string tags: Re-introduced the select all option to select all states (with a maximum of 10K states).
  • ADMIN only
    • Datasource performance metrics. In ConfigHub you can now have a clear view on the performance of your data source connection in which the index operations execution time, plot operations execution time and sync operations execution time are visualized. The values  represent the 50 and 95 percentile over the most recent data. These metrics will make it possible to determine, for example,  the location of an issue faster, by inspecting the metrics of data sources/connectors in ConfigHub and, for example, by excluding the possibilities of related issues such as performances of particular data sources.
  • Search functionality for workflows, types and fields configuration screens in ContextHub.
