Clients
Creating Clients
TrendMiner allows the creation of a client and secret in order to generate a token to be used in external API calls.
To create a new client you will need to go to the clients-menu under the "security" section. From there clients can be created via the "+add client"-button.
You will be asked to enter a name (client ID) for your client which will be used for external references. Once the client is created you can click on it to:
Edit the client ID
Show the secret of the client
Generate a new secret
Delete the client
Regenerating a secret will invalidate your old secret and tokens. This action cannot be undone.
Clients need to be added to a domain/entity in the Access management menu just as users/groups to allow access to the data.
Fetch Token
A token can be fetched via curl or any other means. An example is shown below.
A new token needs to be fetched when the token expires after 5 minutes.
Template:
curl --request POST \ --url 'https://YOUR_DOMAIN/oauth/token' \ --header 'content-type: application/x-www-form-urlencoded' \ --data grant_type=client_credentials \ --data client_id=YOUR_CLIENT_ID \ --data client_secret=YOUR_CLIENT_SECRET
Example:
--url 'https://trendminer.example.net/auth/realms/trendminer/protocol/openid-connect/token' \
--data client_id=external-client \
--data client_secret=35c07824-5e11-40f5-88f0-0b578b940b43Response token:
"access_token":
"expires_in": 300,
"refresh_expires_in": 0,
"token_type": "Bearer",
"scope": "email profile"
