How does TrendMiner determine tag type?
When using a supported TrendMiner connector, the tag types and interpolations used in the historian will be converted to one of the tag types supported by TrendMiner.
For ODBC data sources, the tag type mapping can be configured as explained in the linked articles.
For other connectivity options to common data historians TrendMiner uses the type mappings as listed in the tables below:
  • Aveva Pi
    Historian Type
    Mapped TrendMiner Tag Type
    OLEDB D, SDI PIPointType.Digital
    DIGITAL
    OLEDB S, SDI PIPointType.String
    STRING
    OLEDB others
    ANALOG
    PIPoint.Step Property = True
    DISCRETE
  • IP21
    A special query is executed when using the plug-&-play connector that gets information if the interpolation type is stepped and information regarding the value’s ‘display length’. Given this, TrendMiner will assign any one of the supported tag types. The default mapping for different combinations of settings in InfoPlus to the options available in TrendMiner is as follows:
    Table 15.
    IP_STEPPED
    IP_TREND_VALUE[1]
    IP_VALUE_FORMAT -> #_OF_SELECTIONS
    IP_VALUE_FORMAT -> DISPLAY_LENGTH
    TrendMiner tag type
    >0
    >0
    DISCRETE
    >0
    DIGITAL
    NOT NULL
    AND NOT (NULL_As_Numeric = True && Empty String)
    AND NOT (REAL or INTEGER)
    STRING
    Stepped
    DISCRETE
    All other cases
    ANALOG
  • Aveva Wonderware
    Historian Type
    DoubleByteString, SingleByteString, Event, Structure
    STRING
    Double, Float
    ANALOG
    Considering RawType (Int1, Int2, Int4, UInt2, UInt4) and TagInterpolationType property
    DISCRETE or ANALOG
  • GE Proficy
    Historian Type
    FixedString, VariableString, Time
    STRING
    Bool
    DISCRETE
    Considering StepValue (true or false) property
    ANALOG (false); DISCRETE (true)
  • Exaquantum
    Historian Type
    String
    STRING
    Integer/long and discrete aggregation
    DISCRETE
    Others
    ANALOG
  • PHD
    Historian Type
    U (unicode)
    STRING
    C (char)
    STRING
    I (integer)
    DISCRETE
    L (long)
    DISCRETE
    Others
    ANALOG
