On-prem → On-prem with remote storage on AWS/Azure
Warning
This procedure is only supported as from TrendMiner Version 2024.R2.0
In this scenario, the current TrendMiner application is hosted on-premises and the TrendMiner application data will be migrated using remote storage services on AWS or Microsoft Azure.
Here's how you can accomplish this high level. More details will follow after TrendMiner Application 2024.R2.0 has been released.
Upgrade the Current Application:
Provision a New AlmaLinux or RHEL 9 Instance
Install the TrendMiner Application on the new AlmaLinux or RHEL 9 instance
Configure the remote backup in EdgeManager for the CentOS application
Backup the CentOS TrendMiner Application Data
Configure the remote backup in EdgeManager for the AlmaLinux or Redhat 9 Instance
Restore the TrendMiner Application Data on the new AlmaLinux or RHEL 9 Instance
Test the Setup
Switch to the New Setup
