How to run index calls?
We are able to run queries directly from the connector API console. To perform an index call you can do the following query:
 GET /api/v2/tags/indexvalues?historianName=<datasourceName>&tagName=<tagname>&tagType=<tagtype>&interpolationType=DEFAULT&startDate=2021-11-01T00:00:00Z&endDate=2021-12-01T00:00:00.000Z&numberOfIntervals=43200
Parameters historianName, tagName and tagType need to be filled in to match your setup.
numberOfIntervals = the number of times the index resolution fits into the requested time interval. e.g. requesting 1 month of data for a 1 minute index resolution = 30 days * 24 hours * 60 minutes = 43200 minutes = 43200 intervals.
Time period \ index resolution  | 1 minute  | 5 seconds  |
1 day  | 1440  | 17280  |
1 week  | 10080  | 120960  |
1 month (30 days)  | 43200  | 518400  |
1 month (31 days)  | 44640  | 535680  |
Output requirements:
