Patch Release Updates
Wir veröffentlichen in regelmäßigen Abständen Patches. Um E-Mail-Updates zu TrendMiner-Patches zu erhalten, können Sie sich über diesen Link anmelden.
4.29.5 (connector patch)
Fixes an issue where the sync from an APRM data source can fail. All customers with a data source connection to APRM are advised to patch their installation.
2023.R2.0-23
Fixes an issue which can render the TrendMiner installation unstable in case your installation has more vCPU's then minimally required.
Fixes an issue with the rendering of notebook/MLHub tiles on dashboards.
All customers with more then 8 vCPUs who experience instabilities and customers who use notebook/MLHub dashboard tiles are advised to patch their installation."
2023.R2.0-24
Fixes an issue where tag permissions are no longer cached which can lead to degraded performance, slow tag searches and restarts of the security service. Customers experiencing these issues are advised to patch their installation.
2023.R2.0-25
Fixes an issue where the asset service can crash when uploading a very big asset structure via csv import.
Includes vertical scaling of memory for the data source service which implies that if the system memory resources are higher than the minimal system requirements more memory becomes available for the service which connects to data sources. Customers with a high number of data sources and a high number of tags can benefit from this improvement.
2023.R2.0-27
Fixes an issue where the tag index can be wrong in case the tag has a gap of X days without data, where X is double the configured index granularity. Since the default index granularity is 31 days, all customers with a custom index granularity (<16 days) can be impacted and are advised to patch their installation.
2023.R2.0-31
Fixes an issue where users could not be restored or would lose work when their access was temporarily revoked through the LDAP configuration (e.g. when a user is removed from an active DN or filters are adjusted), causing potential unexpected behaviour or errors in ConfigHub, or lost work for the users. All customers with an LDAP integration are strongly advised to upgrade their installation.
