How to check if TrendMiner is deployed as a virtual appliance?
For on-premises and private cloud installations, TrendMiner can be installed as a virtual appliance or as a so called single node installation as clarified here: TrendMiner Server Installation.
An easy way to check if you are running TrendMiner as a virtual appliance or a single node is by opening ConfigHub and checking the left menu. If you see a section called "APPLIANCE" you know you are running TrendMiner as a virtual appliance.
Single node installations will not show this section in ConfigHub.
 Note that TrendMiner also has a <tm_url>/appliance endpoint which exposes the appliance manager. This endpoint is available on both virtual appliance and single node installations and is therefore unrelated to the TrendMiner deployment method.
