Patch Release Updates
5.3.3 (CONNECTOR PATCH)
Fixed an issue that prevented indexing and plotting data for STRING tags from IP21 data sources.
2026.R2.0-12
Fixed an issue in current value dashboard tiles which could cause an infinite loop, leading to thread exhaustion and recurrent high CPU utilization.
Fixed an issue where access rules on deleted users could cause context permission synchronization issues.
Fixed an issue in ConfigHub diagnostics where live sync incorrectly reported "no activity" even when recent context items were actively syncing.
2026.R2.0-11
Contains some internal firewall improvements which could cause some issues with saving MLHub notebook.
Fixed an issue where DashHub dashboards automatically jumped scroll positions when refreshing external PDF content in Live Mode.
Fixed an issue where error messages in ConfigHub diagnostics were not readable in dark mode.
Fixed an issue where shared space user accounts are logged out unexpectedly.
5.3.2 (CONNECTOR PATCH)
Added a configurable concurrency limit for PHD data sources for improved performance, replacing old connection pooling functionality.
Expanded special character support for IP21 tags.
2026.R2.0-10
Contains some internal firewall improvements which could cause some issues with charting, searches or creating items in TrendHub.
Cleans up old log files, making log uploads easier/faster.
Fixes an issue causing remote backups to Azure or AWS to fail.
Fixes an issue causing the restore of a remote backup from Azure or AWS to fail.
Prevents restoring a failed remote backup.
Fixes an issue where all monitors can stop firing alerts in case of a permission change for one of the monitors.
Fixes an important issue with the EF live sync.
Fixes an issue where the tag dependency browser incorrectly marked a tag-builder tag as owned by the current user.
2026.R2.0-09
Fixes an issue with root volume filling up, causing disk space alert mails being sent. This primarily affects virtual appliances.
Fixes an issue where (monitor) mails were not sent if the email domain cannot be resolved on the server.
Fixes an issue with missing service logs.
Fixes an issue with saving the homepage configuration in ConfigHub.
Fixes an issue where 'Last Modified' date is only shown for the first 15 recently used views in TrendHub.
Fixes a small UI issue for Firefox users.
5.3.1 (CONNECTOR PATCH)
Fixes critical security vulnerability CVE-2025-6965 in SQLite.
The AppHost connector now also supports Wonderware x64.
2026.R2.0-08
Fixes issue with chart data export (xlsx) and search result export.
Fixes an index manager filter issue.
Added feedback message when downloading connector logs in ConfigHub.
