Warning
Security recommendation
To ensure secure communication between TrendMiner and your data sources, we strongly recommend enabling security features for the connector. This includes:
Enabling these features helps prevent unauthorized access and protects sensitive data from interception.
Table 2. Plant Integration requirements
Resource
Amount
vCPU
2
RAM
2GB
Disk Space
5GB
  • One of the following OS's: Windows Server 2012 R2, Windows Server 2016, Windows Server 2019, Windows Server 2022, Windows Server 2025, Windows 10, Windows 11
  • IIS 7 or higher
  • .NET Framework 4.8 or higher
  • IIS Web Deploy 3.5 or higher
  • For Aveva PI: the PI AF SDK drivers provide good connection pooling and efficient transfer. The Plant Integrations and historian need not be co-located.
  • For other historians, TrendMiner recommends installing Plant Integrations on the historian server, as their drivers are normally firewall-unfriendly or latency-sensitive, mostly using DCOM. Experience tells us that an installation on the historian server leads to a better performance than installations that simply use the same network.
