Patch Release Updates
5.1.6 (CONNECTOR PATCH)
  • Re-introduced connection pooling for PHD data sources for improved performance.
5.1.5 (CONNECTOR PATCH)
  • Fixes critical security vulnerability CVE-2025-6965 in SQLite.
5.1.4 (CONNECTOR PATCH)
  • Aligns the tag sync timeout for the AppHost connector from 100 seconds to 15 minutes, in line with the WebHost timeout.
  • Default log level for the connector is reverted from info to warn to avoid excessive logging (both for AppHost and WebHost).
2025.R4.0-18
  • Fixes CVE-2026-43284. (virtual appliance only). Customers with a self-managed TrendMiner installation are advized to patch their server.
We strongly recommend to upgrade virtual appliances.
2025.R4.0-17
  • Fixes CVE-2026-31431 (virtual appliance only). Customers with a self-managed TrendMiner installation are advised to patch their server.
  • Fixes rare issue with backward indexing getting stuck 'in progress'.
2025.R4.0-15
  • Fixes an issue with logs getting cut off.
  • Fixes an issue with logs filling up the root partition disk space.
  • Web application firewall changes have been applied to resolve an issue with MLHub.
We strongly recommend customers to upgrade.
5.1.3 (CONNECTOR PATCH)
  • Fixes an issue with indexing string tags for PHD data sources.
2025.R4.0-14
  • Contains an openssh patch.
  • Fixes some upgrade issues.
  • Fixes issue where string tag gets converted to integer in scientific notation in the statistics table.
  • Fixes issue where exporting value based search result with added integral calculation is failing.
  • Fixes an issue with an inaccurate calculation of the forward integral aggregation under specific conditions.
  • Fixes issue where tags with ‘\' in the tag name could not be loaded by non-admin users.
2025.R4.0-12
  • Fixes several upgrade issues.
2025.R4.0-10
  • Fixes Ingress-Nginx Security issue CVE-2026-24512.
  • Fixes a stability issue with custom calculations.
  • Fixes a UI issue in the index manager causing the tag name to be invisible on small screens.
  • Fix that filters out recently transferred items from the recent and favorite items on the home page.
2025.R4.0-07
  • Contains a significant performance improvement for the tag search.
  • Fixes issue with the stability of the queueing service.
We strongly recommend customers to upgrade to avoid performance issues.
5.1.2 (connector patch)
  • Fixes an issue which breaks Aveva PI connections after an upgrade in case no username/password is filled in (PI Trust).
  • Fixes an issue which breaks connections based on SQLite after an upgrade due to a missing dll.
2025.R4.0-06
  • Includes a significant performance improvement for checking tag permissions which impacts tag searches, loading views, monitors, ...
  • Improves the last-value endpoint which is used in the DashHub current value tiles.
