Step 1: Prepare
Good preparation makes half the work. This section provides an overview of the high-level TrendMiner architecture, server requirements, who to involve in the installation process and a preparation checklist to ensure a smooth installation journey.
Who to involve?
Depending on your organisations size and structure, multiple people from your IT and OT organizations might need to be involved to get TrendMiner up and running, configured and connected to your data sources. We recommend reaching out to everyone involved and discussing the installation process early to avoid any delays later on.
The following roles are typically involved:
Server provisioning and maintenance
To provide the necessary (virtualized) servers according to the requirements, create and maintain snapshots of the Virtual Machine and provide console access for troubleshooting when needed.
Networking specialists
To make the necessary network port and firewall configurations to allow traffic between the TrendMiner server, Plant Integrations and your data sources, and to allow end users to access TrendMiner through their web browser. They will also be able to help out on DNS, NTP and mail relay configuration or connect you to the people who can.
System security
To generate (and update) the necessary SSL certificates for secure access to TrendMiner.
Data source admins
To provide access to the data and deliver data queries if you use a generic connector.
SAML/LDAP admin
While we recommend managing TrendMiner users locally within TrendMiner for initial Explore programs, it is possible to connect TrendMiner to your SAML or LDAP user management system. Involve your SAML/LDAP admin to set up the configuration.
Make sure to discuss responsibilities during the initial installation process as well as for future upgrades and support needs.
Preparation checklist (single node)
Validate the TrendMiner architecture within your organization. Discuss any open questions with TrendMiner Support.
Provision the necessary servers, according to the requirements discussed earlier.
Involve all IT and OT stakeholders early. Read through the installation documentation and discuss roles and responsibilities. Discuss any open questions with TrendMiner Support.
Gather the required input for the server config: IP address and netmask, network gateway, DNS servers, NTP servers, mail relay.
Prepare SSL certificates for secure TrendMiner access (more information Configure SSL/HTTPS)
Prepare input for data source connection(s) (more information Step 4: Connect)
[Optional] Prepare input for SAML or LDAP user management integration (more information Identity Providers)
Server requirements (single node)
Resource | Minimum | Minimum with MLHub[a] | Recommended | ||||||||||||||||||||||||||||||||||||||||||||||
vCPU | 16 | + 1 core per 4 active kernels (per user) + 1 core per 8 notebook tiles (per user per dashboard) | 16 | ||||||||||||||||||||||||||||||||||||||||||||||
RAM | 64GB | + 1GB per active kernel (per user) + 256MB per notebook tile (per user per dashboard) | 96GB | ||||||||||||||||||||||||||||||||||||||||||||||
Disk | SSD, 200GB + 300GB, 250MB/s | SSD, 200GB + 300GB, 250MB/s | SSD, 200GB + 300GB, 250MB/s | ||||||||||||||||||||||||||||||||||||||||||||||
[a] Contact your Customer Success Manager for more information on MLHub Notebook and Machine Learning Model capabilities | |||||||||||||||||||||||||||||||||||||||||||||||||
Disk type: To verify your disk is not rotational (like a HDD) execute the
lsblkcommand. This should show a "0" in the RO column for the root (/) and /mnt/data mount points.Disk space: The required disk space highly depends on the usage of the system: number of users and the amount of items they save on the system + the number of tags which are added and indexed. If usage increases further disk space increases might be required.
Disk speed: TrendMiner performs a lot of read/write actions on the disk hence it is important to verify that the minimal disk speed requirements are met.
The following commands can be used to measure the disk speed:
The root volume contains system logs and services and should have at least 10GB of disk space.
The /mnt/data volume stores all TrendMiner application data and logs. Important notes about the /mnt/data mount point:
xfs_info /mnt/data/. In the resulting output you should seeftype=1. If ftype=0 the volume should be reformatted to support d_type.
For AlmaLinux 9:
AlmaLinux 9 - BaseOS
AlmaLinux 9 - Extras
AlmaLinux 9 - AppStream
For RHEL 9:
rhel-9-for-x86_64-appstream-rpms
rhel-9-for-x86_64-baseos-rpms
Before starting the installation make sure the DNS server is not running. To check if a DNS server is running and to stop and disable the DNS server use the following commands:
lsof -i :53 systemctl stop systemd-resolved systemctl disable systemd-resolved
When a DNS config is changed after initial installation a reboot of the server is required to ensure the new DNS config is used by TrendMiner.
TrendMiner installation requires ansible to be installed on the server.
It's required to use the EPEL repository for installing ansible https://docs.fedoraproject.org/en-US/epel/ (the ansible-core package is missing some plugins which TrendMiner requires and can therefore not be used!)
On RHEL9:
subscription-manager repos --enable codeready-builder-for-rhel-9-$(arch)-rpms dnf install https://dl.fedoraproject.org/pub/epel/epel-release-latest-9.noarch.rpm dnf install ansible
On AlmaLinux9:
dnf config-manager --set-enabled crb dnf install https://dl.fedoraproject.org/pub/epel/epel-release-latest-9.noarch.rpm dnf install ansible
sudo dnf remove iptables iptables-libs iptables-services sudo dnf config-manager --set-disabled epel sudo dnf install iptables iptables-services iptables-nft --disablerepo=epel
The TrendMiner appliance uses Kubernetes (K3S) as its infrastructure layer, which needs a range of IP addresses for internal communication between different pods and services. These IP addresses should not be used by other applications/servers/clients which need to connect to TrendMiner or to which TrendMiner needs to connect, e.g. IPs assigned to clients connecting to TrendMiner, an AD server configured in TrendMiner, a connector to which TrendMiner needs to connect, ...
If your company is already using one or more of these IP addresses it is possible to change the IP ranges for TrendMiner. In this case please contact TrendMiner support before starting the installation.
More info about the appliance IP requirements can be found here: Appliance IP requirements FAQs
sudo ps -ef | grep mdatp)Trend Micro AV (
sudo ps -ef | grep ds_agent)Crowdstrike (
sudo ps -ef | grep falcon-sensor)
If you have a proxy configured TrendMiner installation might fail. Please make sure no proxy is configured until after the installation of TrendMiner.
After the installation, please make sure the following domains and IPs are excluded from using the proxy: localhost, 127.0.0.1, .cluster.local, service.consuland all the IP ranges used by K3S as documented here: Appliance IP requirements FAQs.
option 1 (preferred):
to: license.trendminer.cloud (DNS based IP whitelisting)
port: TCP 443
option 2:
to: 13.248.161.236 and 3.33.158.180
port: TCP 443
