Resource | Amount |
vCPU | 2 |
RAM | 2GB |
Disk Space | 5GB |
Windows Server 2012 R2 or higher
IIS 7 or higher
.NET Framework 4.8 or higher
IIS Web Deploy 3.5 or higher
For Aveva PI: the PI AF SDK drivers provide good connection pooling and efficient transfer. The Plant Integrations and historian need not be co-located.
For other historians, TrendMiner recommends installing Plant Integrations on the historian server, as their drivers are normally firewall-unfriendly or latency-sensitive, mostly using DCOM. Experience tells us that an installation on the historian server leads to a better performance than installations that simply use the same network.
