Prepare the Installation
System requirements
Disk speed
TrendMiner performs a lot of read/write actions on the disk hence it is important to verify that the minimal disk speed requirements are met.
The following commands can be used to measure the disk speed.
#create a test file in /run which we will write to /mnt/data
dd if=/dev/urandom of=/run/test.bin bs=1M count=1024 status=none
#write the test file to /mnt/data and measure the disk write performance of /mnt/data. This is the result to take into account.
dd if=/run/test.bin of=/mnt/data/test1.bin bs=1M conv=fsync
#remove the test files again
rm /run/test.bin /mnt/data/test1.bin
Disk type
To verify your disk is not rotational (like a HDD) execute the lsblk command. This should show a "0" in the RO column for the root (/) and /mnt/data mount points.
CPUs
Memory
Prep the mount point
The root volume contains system logs and services and should have 10GB[1] (or more) disk space.
The /mnt/data volume stores all TrendMiner application data and logs.
Important notes about the /mnt/data mount point:
  • Ensure that this directory has sufficient free disk space. If TrendMiner runs out of available disk space services will start failing leading to downtime for the users. Ensure that at least the minimal required disk space is available and keep in mind that as usage of the system grows, the available disk space might need to be extended.
  • Make sure /mnt/data is mounted to a non-volatile/permanent disk to avoid a broken TrendMiner installation after a server reboot. To make sure this is the case, create a dummy file in /mnt/data, perform a reboot and verify your dummy file is still available.
  • TrendMiner requires d_type support for the /mnt/data volume. To check this run command xfs_info /mnt/data/. In the resulting output you should see ftype=1. If ftype=0 the volume should be reformatted to support d_type.
Root permissions
Repository access
For AlmaLinux 9:
  • AlmaLinux 9 - BaseOS
  • AlmaLinux 9 - Extras
  • AlmaLinux 9 - AppStream
For RHEL 9:
  • rhel-9-for-x86_64-appstream-rpms
  • rhel-9-for-x86_64-baseos-rpms
Check to make sure no DNS server is running
lsof -i :53
systemctl stop systemd-resolved
systemctl disable systemd-resolved
Install Ansible
It's required to use the EPEL repository for installing ansible  https://docs.fedoraproject.org/en-US/epel/ (the ansible-core package is missing some plugins which TrendMiner requires and can therefore not be used!)
On RHEL9:
subscription-manager repos --enable codeready-builder-for-rhel-9-$(arch)-rpms
dnf install https://dl.fedoraproject.org/pub/epel/epel-release-latest-9.noarch.rpm
dnf install ansible
On AlmaLinux9:
dnf config-manager --set-enabled crb
dnf install ansible
Install ip-tables packages
sudo dnf remove iptables iptables-libs iptables-services
sudo dnf config-manager --set-disabled epel
sudo dnf install iptables iptables-services iptables-nft --disablerepo=epel
Network configuration
Check IP address usage
DNS server
Other software
  • Microsoft Defender Advanced Threat Protection (sudo ps -ef | grep mdatp)
  • Trend Micro AV (sudo ps -ef | grep ds_agent)
  • Crowdstrike (sudo ps -ef | grep falcon-sensor)
[1] In theory the root volume should only have 5GB of disk space but since additional logging and monitoring can be configured in a self-managed appliance in practice this 5GB can run full in which case TrendMiner can go down.
