Prepare the Installation
System requirements
Disk speed
TrendMiner performs a lot of read/write actions on the disk hence it is important to verify that the minimal disk speed requirements are met.
The following commands can be used to measure the disk speed.
Disk type
To verify your disk is not rotational (like a HDD) execute the lsblk command. This should show a "0" in the RO column for the root (/) and /mnt/data mount points.
CPUs
Memory
Prep the mount point
The root volume contains system logs and services and should have 10GB[2] (or more) disk space.
The /mnt/data volume stores all TrendMiner application data and logs.
Important notes about the /mnt/data mount point:
xfs_info /mnt/data/. In the resulting output you should seeftype=1. If ftype=0 the volume should be reformatted to support d_type.
Root permissions
Repository access
For AlmaLinux 9:
AlmaLinux 9 - BaseOS
AlmaLinux 9 - Extras
AlmaLinux 9 - AppStream
For RHEL 9:
rhel-9-for-x86_64-appstream-rpms
rhel-9-for-x86_64-baseos-rpms
Check to make sure no DNS server is running
lsof -i :53 systemctl stop systemd-resolved systemctl disable systemd-resolved
Install Ansible
It's required to use the EPEL repository for installing ansible https://docs.fedoraproject.org/en-US/epel/ (the ansible-core package is missing some plugins which TrendMiner requires and can therefore not be used!)
On RHEL9:
subscription-manager repos --enable codeready-builder-for-rhel-9-$(arch)-rpms dnf install https://dl.fedoraproject.org/pub/epel/epel-release-latest-9.noarch.rpm dnf install ansible
On AlmaLinux9:
dnf config-manager --set-enabled crb dnf install https://dl.fedoraproject.org/pub/epel/epel-release-latest-9.noarch.rpm dnf install ansible
Install ip-tables packages
sudo dnf remove iptables iptables-libs iptables-services sudo dnf config-manager --set-disabled epel sudo dnf install iptables iptables-services iptables-nft --disablerepo=epel
Network configuration
Check IP address usage
DNS server
Other software
sudo ps -ef | grep mdatp)Trend Micro AV (
sudo ps -ef | grep ds_agent)Crowdstrike (
sudo ps -ef | grep falcon-sensor)
[2] In theory the root volume should only have 5GB of disk space but since additional logging and monitoring can be configured in a self-managed appliance in practice this 5GB can run full in which case TrendMiner can go down.
