Bug Fixes
  • Fixed an issue where test connection was working incorrectly for the HC (Connector-to-Connector) provider. Now when admin user clicks on the 'Test connection' button, it checks whether "referenced connector" is reachable and whether data source exists on the “referenced” connector with the same name (if not, the error will be logged in the log file).
  • No logs for TrendMiner appliances due to rsyslog permission issues are fixed.
  • Fixed an issue where the tag dependency browser was not accessible when tags are part of a group in the active tag list
  • Fixed an issue where monitors could not be saved in case the Technical Identifier of the context item type was longer than 36 characters
  • Fixed an issue where a large change in tag value (multiple orders of magnitude) could lead to a small offset in the average calculations
  • Fixed several issues with notebooks and notebook tiles.
