Backup types compared
There are mainly 3 ways to backup your TrendMiner appliance data:
Taking a local database backup
Taking a remote full backup
Taking a VM snapshot
A local database backup contains only the database data (typically user generated data). This is the bare minimum to safeguard your data. It does not include index data or system configuration and is not suited for disaster recovery. The main purpose of a local database backup is troubleshooting (e.g. compare data from before and after an upgrade in case of data migration upgrade issues). The backup is created and stored on the local TrendMiner server but can be downloaded to safeguard it in case the server becomes unusable. Local database backups can only be created manually.
Caution
Important note for MLHub customers: database backups do not contain saved PMML models!
A remote full backup contains next to the database data also the index data and the server independent system configuration. It can be used for disaster recovery but it will takes some time and effort since server configuration is not stored and needs to be redone. Remote full backups are stored in the cloud or on the local network, but not on the TrendMiner server itself. Full backups can be created manually or via an automatic backup schedule.
A VM snapshot is the most complete backup. It contains everything: database data, index data, server configuration, ... and is therefor the most complete option for disaster recovery. For this reason VM snapshot are mandatory before starting a big important configuration change or a TrendMiner upgrade. VM snapshots are created and managed outside of TrendMiner.
Local database backup | Remote full backup | VM snapshot | |
Content | Only database data | Database data + index data + server independent system configuration | Full state: database data + index data + server configuration |
Main purpose | Troubleshooting | Disaster recovery + server migrations | Disaster recovery |
Creation | Manual | Manual or scheduled | Manual or scheduled |
Retention period | Indefinite/until manually deleted | 30 days | Configured by customer |
Storage location | On TrendMiner server | Customer network or cloud | Customer network or cloud |
