Known Limitations
Conditional formatting for the Gantt will not consider any changes to duration propagated using live mode. To see the updated coloring, you must refresh the chart.
External content tiles in dashboard need cookies to properly load all content (and be able to login when required).
When calculated tags are deleted, they cannot be created with the same name again.
After renaming a calculated tag linked to a context item, the component of the context item is not updated correctly.
The action displayed on the right-side panel of ConfigHub when a service is restarted, is no longer visible.
The CSV import fails when importing context items for an asset that does not have any yet.
