Known Limitations
  • Conditional formatting for the Gantt would not consider any changes propagated through the use of live mode. To see the updated coloring users would have to refresh the chart.
  • Embedding TrendMiner in external applications is limited to Microsoft Teams. Extensions to improve this functionality and make it more robust coming later.
  • External content tiles in dashboards need cookies to properly load all content (and be able to log in when required).
  • The action displayed on the right-side panel of ConfigHub when a service is restarted is no longer visible.
  • After the upgrade to 2023.R3.0, you may need to clear your browser cache when working in ConfigHub. Otherwise, old menu items that were moved to Edge Manager might still show and cause a logout when you try to access them (e.g. the Diagnostics, TrendMiner upgrade, ...).
