Bug Fixes
  • Numeric Mismatch – Context sync has been repaired to ensure numeric context fields are updated when they are changed in an external system.
  • Scatter plot update – Scatter plots now update correctly when switching axes while a drawn area is visible.
  • “Unsaved changes” label in ContextHub – some filter combinations in ContextHub resulted with an erroneous “Unsaved changes” label on the title bar.  The label now reflects saved changes as expected.
  • Fixed an issue where monitors could become system-disabled due to an incorrect tag accessibility check. In rare cases, the tag accessibility failed, even though the monitor was healthy. Improvements are implemented to avoid such scenarios.
