Introduction
The Context SQL Sync REST service allows importation (either one-time or by scheduling a continuous job) of context data from an SQL database (PostgreSQL, MySQL, or MS SQL) to TrendMiner.
To conduct a synchronization, the service requires two components: a datasource and a query. The datasource defines the connection to the SQL database, from which the data will be fetched. The query provides the SQL query (along with other details as explained later in this document) that will be used to select rows based on a specified time interval. The Context SQL Sync service will create a new context item in TrendMiner (or update an existing item) from each row selected by the query.
Finally, when doing a live sync, a third component is required - a sync job. The sync job encapsulates details, such as the datasource and query that should be used, and the sync frequency, etc.
The steps to sync context data are:
Request an access token for authentication
Define a datasource
Define a query
Perform a one-time sync
or
Define and execute a continuous sync job
