Prerequisites
Tip
After upgrading to TrendMiner version 2023.R3.0, part of the ConfigHub functionality will be moved to Edge Manager, a new interface for system and network administrators to keep your installation healthy and up-to-date. Refer to Edge Manager for the services health overview, diagnostics (downloading log files), future upgrades (including hotfixes) and general network settings. Information on how to access Edge Manager can be found here.
  • My current installed TrendMiner version is 2023.R2.0 or higher.
    In case you are running on version 2023.R1.0 or older, please upgrade first to version 2023.R2.0.
  • I have VM console access.
  • I have updated the CentOS 7 default repository references.
    Notice
    This prerequisite only applies to single node deployments running on CentOS 7. If in doubt about your TrendMiner deployment mode you can check if you are running TrendMiner as a virtual appliance or a single node as documented here: How to check if TrendMiner is deployed as a virtual appliance?How to check if TrendMiner is deployed as a virtual appliance?
    sed -i 's/^mirrorlist/#mirrorlist/g' /etc/yum.repos.d/CentOS-*.repo
    sed -i 's|#baseurl=http://mirror.centos.org|baseurl=http://vault.centos.org|g' /etc/yum.repos.d/CentOS-*.repo
    Resource
    Minimum
    Recommended
    vCPU
    8
    16
    16
    RAM
    32GB
    64GB
    64GB
    Disk space
    SSD, 200GB, 250MB/s
    SSD, 500GB, 250MB/s
    SSD, 500GB, 250MB/s
