Validation
ACL Validation
  1. Log in to TrendMiner at http://<trendminer_address>/
    login screen
  2. Go through the first login procedure:
    • Accept the EULA
      Astuce
    • Accept the privacy policy
    • Update your password according to the password policy rules
    • Update you account information
    • Update your job profile
  3. Click on 'search tags and attributes' followed by the filter icon to verify that the connections and permissions as configured in the previous sections are correct. Under 'Data sources' you should see a list of all data sources which are configured in ConfigHub and for which ACLs are assigned to the logged in user.
  4. Start typing a tag name inside of the search box.
  5. Tags that match the input will show up in the dropdown. Click on the plus icon (+) to visualize. TrendMiner displays a trend view of the tag and starts the indexing process.
