Application Enhancements
An overview of your “favourite” items in the work organizer.
The last updated parameter of an item in the work organizer now indicates whether the item has been created or updated together with the date and time of performed action.
Improvements to the restore last session option which now works better with saved items, allowing you to recover a lost unsaved existing view with its unsaved changes.
ContextHub Multi-scatter plot performance improvements.
ContextHub Gantt chart improvements – easily add context items with the most recent timestamp, by using the provided space on the right most side of the chart.
Context fields are now ordered alphabetically in the context item.
MLHub (Machine Learning Hub) notebooks can be opened directly from the Work Organizer.
DashHub Text tile now comes with a smaller footprint to use it as a section header, and a larger edit mode panel.
The DashHub value tile now also contains the unit of measurement of the tag or attributes.
Usability improvements for updating dashboard content to behave less glitchy.
The dashboard grid was improved to allow easier movement and swapping of tiles.
The way tiles move over a dashboard has been improved, no longer pushing other tiles into a direction to make sure your current tile placement is not undone.
Tiles can swap places when moving them, simply hover with you tile on another one. If the tile “fits” on the space of the moving tile, it will swap.
The expire time of being logged into the application has been increased from 30 minutes to 24 hours by default.
