Define a Query
New queries can be defined by the API:
Method: POST Path: /context-sql-sync/query Authorization header: Bearer [access_token] Body { "name": "queryAlias", "supportsParameters": true, "supportsNamedParameters": true, "componentLookupStrategy": "ASSETS|TAGS|ASSETS_THEN_TAGS", "fieldNames": "customField1, customField2", "validateFieldNames": true, "timeZone": "string", "sqlString": "Select id, componentId, type, description, start_event, start_time, stop_event, stop_time, customField1, customField2 from LOGBOOK where :startDate <= start_time and start_time < :endDate;", "typeMapping": [ { "PRODUCTION": "MAPPED_TYPE" }, { "SOURCE_TYPE": "TM_TYPE" } ] }
Parameters | Description | ||||||||||||||||||
name | An arbitrary string. | ||||||||||||||||||
supportsParameters | A boolean value (true|false) indicating whether the SQL query contains positional parameters. The default is true. Positional parameters are specified with question marks '?' in the SQL query. The query should contain exactly two parameters - they will be replaced with the start and end time of the requested time interval respectively. | ||||||||||||||||||
supportsNamedParameters | A boolean value (true|false) indicating whether the SQL query contains named parameters. The default is true. If this property is set to true, it will take precedence over supportsParameters. Named parameters are specified with the ':startDate' and ':endDate' (without the quotes) values in the SQL query - they will be replaced with the start and end time of the requested time interval respectively. | ||||||||||||||||||
componentLookupStrategy | A value specifying how to interpret the componentId returned by the query. The allowed values are ASSETS (componentId is interpreted as the external id of an asset), TAGS (componentId is interpreted as a tag name), and ASSETS_THEN_TAGS (componentId is interpreted as an asset and, if no asset is found, then componentId is interpreted as a tag name). The default is ASSETS. | ||||||||||||||||||
fieldNames | A comma-separated list of values, each representing the name of a column in the SQL query (see below). These columns represent custom fields to be associated with the newly created or updated context items. This property is optional and defaults to null. Bear in mind that the specified values are validated against the SQL query and the request will fail if the field names are not found in the SELECT clause. If the fields exist on the context type associated with the item, the values of the columns specified by this property will be imported as values of the fields with the respective technical names. If they don’t exist, then the column values will be imported as general properties of the context item. | ||||||||||||||||||
validateFieldNames | Optional. If missing or set to true, field names specified in the query will be validated. If set to false, the validation will be skipped. | ||||||||||||||||||
timeZone | Specifies the timezone of the dates in the SQL database. The default is UTC. The list of supported timezones can be found by using the following endpoints: <TM-URL>/hps/api/monitoring/options/timezone/available https://en.wikipedia.org/wiki/List_of_tz_database_time_zones | ||||||||||||||||||
sqlString | The string of the SQL query that will be executed against the datasource to fetch the items. The query is required to return (at least) the following columns (in order): id, componentId, type, description, startEvent, startTime, endEvent, endTime. The query can contain additional columns, but they should come in after these first eight columns. The extra columns are often necessary when using custom fields. Additional information about the individual columns can be found below:
An example SQL query: SELECT id, componentId, type, description, start_event, start_time, stop_event, stop_time FROM some_table WHERE :startDate <= start_time and start_time < :endDate; In addition to the required columns, the SQL query could also select:
typeMapping | A table used to map the values in the type column (see sqlString above) to actual context types in TrendMiner. Even if the type column contains a type that exists, there should be an entry in the typeMapping table that maps the type to itself, e.g.: "typeMapping": [ { "PRODUCTION": "PRODUCTION" } ] |
Example: If the datasource contains a lastModifiedDate column, the query can be modified to select records based on their lastModifiedDate. For example:
{ ... "sqlString": "Select id, componentId, type, description, start_event, start_time, stop_event, stop_time, last_modified_date from LOGBOOK where :startDate <= last_modified_date and last_modified_date < :endDate;"...} ... }
This way, if an item is modified, it will be selected for sync, even if its start time is untouched.
The result will contain the id of the newly created query. This id will be used later.
