Prerequisites
My current installed TrendMiner version is 2022.R2.0 or higher.
In case you are running on version 2022.R1.0 or older, please upgrade first to version 2022.R2.0.
I have VM console access.
I have a recent VM snapshot.
I have a recent database backup.
I have enough free disk space.
I have updated the CentOS 7 default repository references.
Notice
This prerequisite only applies to single node deployments running on CentOS 7. If in doubt about your TrendMiner deployment mode you can check if you are running TrendMiner as a virtual appliance or a single node as documented here: How to check if TrendMiner is deployed as a virtual appliance?
sed -i 's/^mirrorlist/#mirrorlist/g' /etc/yum.repos.d/CentOS-*.repo sed -i 's|#baseurl=http://mirror.centos.org|baseurl=http://vault.centos.org|g' /etc/yum.repos.d/CentOS-*.repo
My system meets the minimum system requirements as listed below.
Resource
Minimum
Recommended
vCPU
8
16
16
RAM
32GB
64GB
64GB
Disk space
SSD, 200GB, 250MB/s
SSD, 500GB, 250MB/s
SSD, 500GB, 250MB/s
All connectors are running on a Windows server with Microsoft .NET 4.8 or higher installed.
As of connector version v4.13.0 the required .NET version is 4.8, compared to .NET 4.5.2 for previous releases.
