How to enable MLHub and machine learning models?
Next to TrendHub, ContextHub and DashHub there is optional MLHub which unlocks notebook functionality. MLHub allows to deploy models which can be used to create machine learning model tags in TrendHub. To use these functionalities, make sure the following prerequisites are met:
  • Make sure you installation matches the requirements with MLHub.
  • Upgrade TrendMiner using the full package that can be downloaded from the usual download location.
    You should be able to see the following services listed in the services overview in ConfigHub:
    • enterprise-gateway
    • tm-ml-hub
    • tm-zementis
    • zementis-jupyter-server
  • Reach out to your CSM to receive a license that includes MLHub and upload that license in ConfigHub.
    After uploading the license, you should see the following:
  • Provide access to MLHub and Machine Learning Tags to individual users as explained here.
