Virtual appliance deployment
VMware ESXi 5.5 or higher
Microsoft Windows Hyper-V Server 2012.R2 or higher
The TrendMiner Virtual Appliance is a complete virtual machine that contains the infrastructure to run TrendMiner. TrendMiner pre-configures the Virtual Appliance to conform to various industry standards related to security including:
Operating System patches are included with each TrendMiner update
A firewall is enabled to limit network access
SELinux is enabled in Enforcing mode
TrendMiner services run isolated in pods
The TrendMiner Virtual Appliance provides a management interface to configure the infrastructure. Operational concerns can be configured here. Basic level monitoring is included in the Virtual Appliance. Mail alerts will be sent to a configurable mail address when the available disk space is less than 20% or when critical application components fail.
Required input to complete a Virtual Appliance install includes:
IP address and netmask
Network gateway
DNS servers: name resolution of other services
NTP servers: ensure time synchronization, required for security and a consistent UX
Mail relay: required to use admin and functional monitoring capabilities
Other prerequisites:
Full root permissions on the Linux OS (running the command
id
should result in something likeuid=0(root) gid=0(root) groups=0(root)
The installation of TrendMiner as a virtual appliance consists of 3 consecutive steps:
