Where to get your private key?
When you request a certificate the CA (certificate authority) will generate a certificate and a private key. The certificate and the private key can be sent over in a single file (e.g. a .pfx file) or as a separate files.
To enable SSL the private key needs to be uploaded separately so in case a single pfx file is received a manual action is required to extract the private key from the pfx file.
With openssl the following command can be used to extract the private key from the pfx file:
openssl pkcs12 -in filename.pfx -nodes -nocerts -out private.key
The "-nodes" (no DES) option prevents the private key from being encrypted. This is essential as TrendMiner does not support uploading an encrypted private key.
The "-nocerts" option makes sure no certificates are in the output file and only the private key will be output.
Since the pfx file contains the private key it is passphrase protected and you will be prompted to enter the passphrase when executing the command. You should have received the passphrase from your IT department or CA.
Alternatively you can convert the pfx file to a pem file first and then extract the private key with the following command:
openssl x509 -in filename.pem -nocerts -out private.key
As a third option you can convert the pfx file to a pem file first and then extract the private by manually copying it:
  • Open the .pem file with a text editor
  • Copy everything between "-----BEGIN PRIVATE KEY-----" and "-----END PRIVATE KEY-----", including these 2 lines
  • Save the copied text to a new text file and save it as a .key file
