Prepare the Installation
System requirements
Disk speed
TrendMiner performs a lot of read/write actions on the disk hence it is important to verify that the minimal disk speed requirements are met.
The following commands can be used to measure the disk speed.
#create a test file in /run which we will write to /mnt/data
dd if=/dev/urandom of=/run/test.bin bs=1M count=1024 status=none
#write the test file to /mnt/data and measure the disk write performance of /mnt/data. This is the result to take into account.
dd if=/run/test.bin of=/mnt/data/test1.bin bs=1M conv=fsync
#remove the test files again
rm /run/test.bin /mnt/data/test1.bin
Disk type
To verify your disk is not rotational (like a HDD) execute the lsblk command. This should show a "0" in the RO column for the root (/) and /mnt/data mount points.
CPUs
Memory
Prep the mount point
The root volume contains system logs and services and should have 10GB[2] (or more) disk space.
The /mnt/data volume stores all TrendMiner application data and logs.
Important notes about the /mnt/data mount point:
  • Ensure that this directory has sufficient free disk space. If TrendMiner runs out of available disk space services will start failing leading to downtime for the users. Ensure that at least the minimal required disk space is available and keep in mind that as usage of the system grows, the available disk space might need to be extended.
  • Make sure /mnt/data is mounted to a non-volatile/permanent disk to avoid a broken TrendMiner installation after a server reboot. To make sure this is the case, create a dummy file in /mnt/data, perform a reboot and verify your dummy file is still available.
  • TrendMiner requires d_type support for the /mnt/data volume. To check this run command xfs_info /mnt/data/. In the resulting output you should see ftype=1. If ftype=0 the volume should be reformatted to support d_type.
Root permissions
Repository access
Access to the official OS repositories or a mirror of them is required. TrendMiner has no extra requirements when installing on a customer-provided CentOS 7 or Red Hat Enterprise Linux 7 system outside of the software that is available in the official operating system repositories.
For CentOS7:
  • CentOS-7 - Base
  • CentOS-7 - Extras
  • CentOS-7 - Updates
For RHEL 7:
  • rhel-7-server-rpms
  • rhel-7-server-extras-rpms
  • rhel-7-server-ansible-2-rpms
To list all available repos on the system use yum repolist . TrendMiner will add another repo called tm-appliance during installation.
To check which repos are configured, use the yum repolist -v enabled command and check the Repo-baseurl.
Install Ansible
To install Ansible and be able to run the full installation procedure run the following command:
yum install centos-release-ansible-29
Network configuration
Check IP address usage
DNS server
Other software
Examples of virus scanner which are known to cause interference with TrendMiner are:
  • Microsoft Defender Advanced Threat Protection (sudo ps -ef | grep mdatp)
  • Trend Micro AV (sudo ps -ef | grep ds_agent)
[2] In theory the root volume should only have 5GB of disk space but since additional logging and monitoring can be configured in a self-managed appliance in practice this 5GB can run full in which case TrendMiner can go down.
