Known limitations
  • The cross-asset value-based search is not available in TrendHub Next Generation.
  • Scooter values may change when zooming in after adding the scooter. This is due to the fact that scooters currently interpolate the data points on the chart.
  • The jupyter notebook files and output pipeline are not backed up automatically by TrendMiner in this release. You can recover them from your VM snapshots or upload them via the ‘import’ function.
  • When sharing notebooks with other users via the Work Organizer, they are shared in view only mode. Modifications by users other than the notebook owner will not be saved.
  • The action displayed on the right-side panel of ConfigHub when a service is restarted, is no longer visible.
