Application Enhancements
  • Search results indications: Search results are displayed at the bottom of the context bar.
  • Advanced Similarity Search: The advanced option allows you to search a pattern of one tag in the history of another tag.
  • Context Item Search – Layering improvements: Select and remember which attribute to visualize when the search result is linked to an asset.
  • Filtering on empty/nonempty values in ContextHub to filter not only based on specific values, but also on empty or non-empty values to, for example, Identify missing information.
  • DashHub Trend tile includes filtered out periods: For a trend plot, filters are shown visually in grey on the tile, while scatterplots and histograms will omit the data.
  • Improved information messages with more options and possibilities to keep the message visible by hovering over or to click away a message immediately.
  • Extended connectivity to AspenTech InfoPlus 21: Next to Aspen SqlPlus queries, connectivity via stored procedures is now also supported.
  • Jupyter notebooks can be imported into the TrendMiner MLHub notebook environment.
  • Notebook outputs can now be published in specific pipeline-work-items within the work organizer for subsequent use as (interactive) visualizations in DashHub. Compared to previous Notebook tiles, these pipeline-objects are resource-scarce, decoupled from the notebook itself to avoid collisions and kernel-isolated.
  • Various Work Organizer UI improvements including visual indications of folder paths, easier access to actions, etc.
  • Windows Server 2022 is a supported operating system to host Plant Integrations.
