Opening additional firewall ports
TrendMiner controls the packet filtering rules of the Linux kernel using iptables. By default, only icmp, ssh (tcp/22), http(s) (tcp/80, tcp/443) and port 8080 are allowed.
    "allow_icmp": true,
    "open_tcp": [
         5666,
         10050
In this example, ports 5666 and 10050 are opened on the TrendMiner instance to allow respectively NRPE and Zabbix connectivity on the system.
python -m json.tool < /etc/ansible/facts.d/iptables.fact
cd /mnt/data/ansible-playbooks
ansible-playbook agent/configure-tm-agent.yml -i /var/www/dsquare-appliance/hosts
The updated configuration will be applied on subsequent reboots and preserved across future TrendMiner updates.
Monitor TrendMiner
TrendMiner collects metrics into a Prometheus instance that is running on every TrendMiner system. Prometheus metrics exporters included in TrendMiner include:
  • Node Exporter exports OS level metrics
  • Postgres Exporter exports database metrics
  • Each TrendMiner service exports JVM metrics
  • Several TrendMiner services export application specific metrics
All metrics are available for external systems through Prometheus federation. Alerts based on these metrics can then be created in an external monitoring stack.
When using a monitoring stack based on Prometheus and AlertManager, Prometheus could be configured as:
scrape_configs:
  - job_name: federated-trendminer
     honor_labels: true
     honor_timestamps: true
     scrape_interval: 15s
     scrape_timeout: 10s
     metrics_path: /federate
     static_configs:
       - targets:
           - <my-trendminer>:9100
AlertManager can then handle alerts:
groups:
  - name: TrendMiner rules
    rules:
      - alert: instance_down_2m
        for: 2m
        labels:
          severity: Critical
        annotations:
          description: TrendMiner DOWN for 2 minutes
          summary: TrendMiner DOWN
