Other historians prerequisites
PHD Historians
Install PHD client tools on the Plant Integration server. Copy the PHDAPINET.dll that is part of the Client tools installation  to the  Plant Integrations bin folder. The default location would be: C:\inetpub\PlantIntegrations\bin
GE Historian
Copy your historian's Proficy.Historian. ClientAccess.API dll file to Plant Integrations bin folder. The default location would be: C:\inetpub\PlantIntegrations\bin
Please open control panel on your historian server-> Program and features-> Search for Proficy and it will show you Proficy software installed on your server. Please take a screenshot and send it to us..
By default Plant Integrations supports GE version 5.5. Please reach out to TrendMiner support, if you have a GE version higher than 5.5, to get a special Plant Integrations build. To create that build TrendMiner support needs Proficy.historian.ClientAccess.API.dll from your historian.
Wonderware Historian
To connect wonderware historian with TrendMiner we need to know the version number of your historian. To check the wonderware version number: Please open control panel on yourhistorian server-> Program and features->Search for wonderware and it will show you wonderware software installed on your server. Please take a screenshot and send it to us.
Currently, TrendMiner does not support Write-Back or Backfilling function to Wonderware Historian.
Yokogawa Exaquantum
Historian Copy the following .dll files from Yokogawa Exaquantum server to the installation's bin folder. The default location would be: C:\inetpub\PlantIntegrations\bin
Please contact TrendMiner Support for guidance during the installation.
