Prepare the Installation
System requirements
Disk speed
TrendMiner performs a lot of read/write actions on the disk hence it is important to verify that the minimal disk speed requirements are met.
The following commands can be used to measure the disk speed.
Disk type
To verify your disk is not rotational (like a HDD) execute the lsblk
command. This should show a "0" in the RO column for the root (/) and /mnt/data mount points.
CPUs
Execute the lscpu
command and verify that the "CPU(s)" listed is in line with the minimal system requirements.
Memory
Execute the free -m
command and verify that the "Total - Mem" listed is in line with the minimal system requirements.
Prep the mount point
The root volume contains system logs and services and should have 10GB[2] (or more) disk space.
The /mnt/data volume stores all TrendMiner application data and logs.
Important notes about the /mnt/data mount point:
xfs_info /mnt/data/
. In the resulting output you should seeftype=1
. If ftype=0 the volume should be reformatted to support d_type.
The available volumes and disk spaces can be verified with the df -h
command.
Root permissions
TrendMiner uses the root user to run commands (e.g. during installation and upgrades). The root user needs sudo permissions. To verify this is the case execute the sudo id
command. The result should be uid=0(root) gid=0(root) groups=0(root)
Repository access
Access to the official OS repositories or a mirror of them is required. TrendMiner has no extra requirements when installing on a customer-provided CentOS 7 or Red Hat Enterprise Linux 7 system outside of the software that is available in the official operating system repositories.
For CentOS7:
CentOS-7 - Base
CentOS-7 - Extras
CentOS-7 - Updates
For RHEL 7:
rhel-7-server-rpms
rhel-7-server-extras-rpms
rhel-7-server-ansible-2-rpms
To list all available repos on the system use yum repolist
. TrendMiner will add another repo called tm-appliance
during installation.
To check which repos are configured, use the yum repolist -v enabled
command and check the Repo-baseurl
Install Ansible
To install Ansible and be able to run the full installation procedure run the following command:
yum install centos-release-ansible-29
Network configuration
Check IP address usage
DNS server
Make sure a DNS server is correctly configured. Verify the configured DNS server by executing cat /etc/resolv.conf
. If a NetworkManager is managing your network settings, make sure the DNS config is not lost after a reboot by verifying the resolv.conf file still contains the DNS server after a reboot.
Other software
Examples of virus scanner which are known to cause interference with TrendMiner are:
sudo ps -ef | grep mdatp
)Trend Micro AV (
sudo ps -ef | grep ds_agent
[2] In theory the root volume should only have 5GB of disk space but since additional logging and monitoring can be configured in a self-managed appliance in practice this 5GB can run full in which case TrendMiner can go down.
