How to run index calls?
We are able to run queries directly from the connector API console. To perform an index call you can do the following query:
GET /api/v2/tags/indexvalues?historianName=<datasourceName>&tagName=<tagname>&tagType=<tagtype>&interpolationType=DEFAULT&startDate=2021-11-01T00:00:00Z&endDate=2021-12-01T00:00:00.000Z&numberOfIntervals=43200
Parameters historianName, tagName and tagType need to be filled in to match your setup:
historianName: the datasource name as specified in ConfigHub
tagName: the name of the tag you want to fetch data for, including the prefix
tagType: type of the tag. All supported TrendMiner tag types are documented here: Welche Tag-Typen werden von TrendMiner unterstützt?.
numberOfIntervals = the number of times the index resolution fits into the requested time interval. e.g. requesting 1 month of data for a 1 minute index resolution = 30 days * 24 hours * 60 minutes = 43200 minutes = 43200 intervals.
Time period \ index resolution | 1 minute | 5 seconds |
1 day | 1440 | 17280 |
1 week | 10080 | 120960 |
1 month (30 days) | 43200 | 518400 |
1 month (31 days) | 44640 | 535680 |
Output requirements:
