Opening additional firewall ports
TrendMiner controls the packet filtering rules of the Linux kernel using iptables. By default, only icmp, ssh (tcp/22), http(s) (tcp/80, tcp/443) and port 8080 are allowed.
{ "allow_icmp": true, "open_tcp": [ 5666, 10050 ] }
In this example, ports 5666 and 10050 are opened on the TrendMiner instance to allow respectively NRPE and Zabbix connectivity on the system.
python -m json.tool < /etc/ansible/facts.d/iptables.fact
cd /mnt/data/ansible-playbooks ansible-playbook agent/configure-tm-agent.yml -i /var/www/dsquare-appliance/hosts
The updated configuration will be applied on subsequent reboots and preserved across future TrendMiner updates.
Monitor TrendMiner
scrape_configs: - job_name: federated-trendminer honor_labels: true honor_timestamps: true scrape_interval: 15s scrape_timeout: 10s metrics_path: /federate static_configs: - targets: - <my-trendminer>:9100
AlertManager can then handle alerts:
groups: - name: TrendMiner rules rules: - alert: instance_down_2m expr: up{job="federated-trendminer"} == 0 for: 2m labels: severity: Critical annotations: description: TrendMiner DOWN for 2 minutes summary: TrendMiner DOWN
